Author Topic: CD scratch remover thingy....  (Read 4837 times)
« on: June 02, 2003, 05:00:02 am »
do those work?
like you can get them for like $30-$50....
Just wondering if anyone has checked them out, and their expierences with them?
Logikal X
    • MSN Messenger - tqhx@hotmail.com
    • AOL Instant Messenger - tqhx
« Reply #1 on: June 02, 2003, 05:34:29 am »
I have one and it works but only a few times on each cd, some cd's just wont repair
The bottom of each cd is actually coated with a hard wax solution, if it scratches then you can remove some of the layer using the cd cleaner, however eventually the layer runs thin and you are out of luck, so it depends what the cd is worth to you, also depends how badly you treat your cd's....i suggest trying to buff the scratches out with a small amount of toothpaste and water first
Quote from: "ReSpektDaFrenziedEVanesSa"
But I have to say I love the feeling of anything going up my butt, it just drives me wild.
« Reply #2 on: June 03, 2003, 05:07:44 pm »
do you use some kind of cloth, with the tooth paste thing?
zurielshimon
    • AOL Instant Messenger - weetbixkid36
    • http://www.myspace.com/193866568
« Reply #3 on: June 05, 2003, 08:29:04 pm »
I had some CD scratch remover once, but blah, never got significant results.  Usually when a CD starts to get bad I'll just put it in the computer and make a new copy.  I've always thought that CDs should be made of glass or should be in a cartridge where the playing surface is never exposed outside the player.  That's my main hangup on ever buying a DVD player.  The next great medium should be like that.
Dustin
Logikal X
« Reply #4 on: June 06, 2003, 05:35:32 am »
Sorry i missed this, i was trying not to overpost  :wink:
Anyways the best thing you can use is probably an old t shirt or some other soft cotton....paper towels and washrags will cause more scratches....but usually when i do it i put a little toothpaste on my finger and rub it in then rinse the cd off and dry with my shirt
