Author Topic: Test  (Read 6247 times)
Test
« on: November 17, 2002, 02:55:58 am »
Wonkies and I are just checking something out relating to the AOL browser window.  It seems that if you have AOL you should open Internet Explorer to get past the problem of being asked for your sn and password over and over again, which can be quite irritating.  This is a test I'm doing to see how well the IE solution works as I've noticed the problem is amplified when starting a new topic...but I could be wrong about that...just checking it out anywho by starting this thread....
Why these posts were reported is beyond me. - Tricia
Test
« Reply #1 on: November 17, 2002, 02:59:55 am »
hmmm.....it seems to be the problem and opening IE is the solution.....so if you have AOL and have this problem try opening IE or maybe some other internet application as AOL sucks.  Or if you have some other problem with a ISP like the problem above try this solution because it has been working without fault for three posts for me.....
this will be the fourth.....
