Author Topic: The ignore & un-ignore  (Read 36371 times)
KULPDOGG
    • http://kulpdogg.googlepages.com
« Reply #15 on: November 12, 2003, 06:51:12 pm »
Quote from: "blackvulture"
the server switchover didnt seem to like the IGNORE MODULE
The bypass to view a particular post does not work and removing a user does not work.
Could not delete user from ignore table
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND user_id = 225' at line 4
DELETE FROM nhforums_phpbb_ignore WHERE user_ignore = AND user_id = 225
Line : 88
File : /home/katia/www/forum.nessaholics.com/htdocs/ignore.php
there is no user with the id 225.
i checked.. unless they're not on the member list
« Reply #16 on: November 12, 2003, 06:54:15 pm »
Quote from: "KULPDOGG"
Look again, I'm 225. So that's not the problem, its the db link between 225 and my ignore list thats getting lost somewhere in SQhelL
KULPDOGG
« Reply #17 on: November 12, 2003, 06:59:57 pm »
well, i noticed that the ids go in order on the memberlist...
but some numbers are missing(i assume from deleted members?)
but other than that they are in order..
and on the list
it goes from
http://forum.nessaholics.com/profile.php?mode=viewprofile&u=224
to
http://forum.nessaholics.com/profile.php?mode=viewprofile&u=226
no 225 in the middle
unless im wrong in thinking that the ids go in order..
i think you're not listed on the member list :?:
edit: oh shoot, my bad.. they're not in order :?
nevermind  :oops:  :oops:
Trolan
    • http://www.trolans.net/
« Reply #18 on: November 13, 2003, 05:59:33 am »
Something about the SQL statement.  It's not a problem with the userid, it's the bit after user_ignore.  WHERE user_ignore = (WHAT?!?).  I'll take a look at it, and if I can't find it, I'll just stick you on my ignore.  :twisted:
DEBUG MODE
Line : 88
Trolan
« Reply #19 on: November 13, 2003, 06:08:39 am »
Should be fixed now.
The authors of the ignore module appear to have forgotten a little detail in how PHP accesses variables from URL/form data, and how it changed the default from PHP 4.1 and 4.2.  As the previous server was installed with 4.1 originally, the defaults in the config file from that period remained in effect, even up to the current version on that server.  This one started at 4.3.4, and therefore is using those defaults, as I tend to agree with them, and it's been almost two years since that change was made.  Portable PHP code shouldn't make the assumption they did.
LifelessPie
    • AOL Instant Messenger - RoxyTatyy+22
« Reply #20 on: November 13, 2003, 12:19:05 pm »
i accidently pressed ignore instead of quote , as well....ut how d oyou get someone off your ignore lists??
"How you gon' say, that I remind you, a yo jeep?!"
Si
  • Down a Rabbithole
« Reply #21 on: November 13, 2003, 12:25:35 pm »
Quote from: "LifelessPie"
Go here
and then click on the little cross on the right of the name of the person you ignored
• SHUT  UP  when  I'm  talking  to  you... !
 You  hear  me?  ANSWER  me !! •
« Reply #22 on: November 13, 2003, 01:01:27 pm »
Quote from: "Trolan"
You're a pimp! Thanks Kelly!
Jameson
    • AOL Instant Messenger - hollyoccala
oops...
« Reply #23 on: January 19, 2004, 04:04:41 pm »
This is going to sound retarded but insted of clicking "quote" i clicked ignore....How do i reverse this? :?:
Quote from: Nicole
My breasts are so big... I never see my feet
"i Pity the fool..."
Re: oops...
« Reply #24 on: January 19, 2004, 04:23:29 pm »
Quote from: "Jameson"
I'm sure Vulture answered this once, but his reply is gone. So...
http://forum.nessaholics.com/ignore.php
It's not so retarted. It's worse when you're a mod and you click [Edit] instead of
then save all over somebody's post :-\ lol
-Kev
Re: oops...
« Reply #25 on: January 19, 2004, 04:26:04 pm »
Quote from: "kev222"
That's not so retarted. It's worse when you're a mod and you click [Edit] instead of (quote) then save all over somebody's post :-\ lol
lmfao! its funny cause it's true!
Re: oops...
« Reply #26 on: January 19, 2004, 04:27:01 pm »
Heh. And only the back button can save you (if you're lucky).
-Kev
« Reply #27 on: January 19, 2004, 04:32:41 pm »
I have never done that... ???  wth?
« Reply #28 on: January 19, 2004, 04:35:34 pm »
Some mods do that for fun :wink:
"What?!  I didn't say that!"
« Reply #29 on: January 19, 2004, 04:35:36 pm »
I've never saved over but I have hit the wrong button and caught myself.
And I've seen mods quote when they meant to edit. hehe Thats not so bad cause it just makes a double post type of thing.
